Hi- I'm learning about basic amplifier configurations, and I'm having trouble understanding the term "common" used in that context. Please see my attachment.
For example, the common emitter configuration shows the output and what is presumably the output ground, but in the real circuit there's a power supply in between the emitter and the output ground, and that output ground is actually the positive terminal of the power supply.
I always thought the term "common" meant a node with the same voltage potential, but that is not the case here. I'm trying to understand the bigger-picture context-- is the output ground somehow connected to ground in other parts of the circuit? If so, wouldn't that short out the power supply?
Thanks in advance for your help. -John
