I can see Q19 which is a 7815C (+15V) and a TIP31C, TIP32C. What is Q22?
That's an L7915CV.
The output measures .755 volts to ground (steady). And the input measures -2.365-2.372 volts to ground (fluctuates).
Well that may explain where the -15V went. What could cause a low input voltage? What do you think is the next step?
I already know the answers but it helps if you think it through.
Based on my limited experience and my last repair, a short along the signal path before the input could cause a low input voltage.
Q19 Voltage Regulator L7815CV
Input 26.98-27.47 volts to ground (fluctuates, ramps up slowly)
Output 15.00 volts to ground (steady)
Ground 0
Q20 Transistor TIP31C
Base 28.23 volts (steady)
Collector 46.32-46.43 volts (fluctuates)
Emitter 27.62-27.64 volts (fluctuates)
Q21 Transistor TIP32C
Base -2.92-2.97 volts (fluctuates)
Collector -46.39-46.48 volts (fluctuates)
Emitter -2.43-2.49 volts (fluctuates)
Q22 Voltage Regulator L7915CV
Input -2.365-2.372 volts to ground (fluctuates)
Output .755 volts to ground (steady)
Ground 0
