Ok friends,
I used a 95W bulb in my current limiter.
What do we have so far: I made a dim bulb current limiter today and tried the unit.
Observations1. I am getting a relay like clicking sound somewhere in the circuit.
2. I feel like i have programmed the unit with the Arduino's blink sketch
. The unit have the exact response as the Arduino's blinking sketch, only with one difference; Arduino blinks an light emitting diode but my unit blinks the dim bulb current limiter's bulb instead, almost with the same frequency.
3.The fan of the unit and the equalizers leds on the front panel turns on for a fraction of a second and off for a fraction of a second and this loop goes on with the bulb blink.
What i should look in the circuit?
What may cause this problem?
If i will desolder the (8,9,10,11) pins as i noted in the image ( it is the primary stage i suppose ) Will the unit start if every part before the transformer's primary stage is not faulty?
Any help will be very valuable.
Thanks!
