I recently bought a T962A and added the ESTechnical aftermarket controller. Not a whole lot of experience with it yet, but I've used it to solder a board with a 400-pin Searay connector and it seemed to do OK.
The ESTechnical controller makes a huge difference. Moving the graph to the PC is helpful in itself. The T962 can't control the temperature of the board very closely, but the graph allows you to tweak the process to get something resembling the desired slope, e.g.:
The USB interface is flaky and requires frequent reconnection and/or power cycling, but the controller itself is solid. It really makes the most of the oven's limited hardware design. In a couple of weeks I'll run a board with an 0.8-mm BGA through it, and we'll see how it holds up. But I have no reason to think it won't do OK.
It's important to use a heat spreader underneath the PCB so I'm going to try some thin brass sheet. Will let you know how it goes.
I haven't heard this before, any pointers?
The advice I've read (and followed with the Searay board) was actually to elevate the board in the drawer slightly by putting a couple of PCB scraps beneath it. The ESTechnical controller uses the fan to provide air circulation during operation, so this seems like a good way to ensure the whole board is preheated adequately.
