Thanks for your continued input.
Just to clarify my situation, I am not a commercial enterprise trying to drum up business, I am just a retiree trying to eke out an existence and enjoy the hobby of metal detecting. I have a display of some of my finds, which I like to share with others, if they are interested. Hence my previous post dated 5th Sept.
The display will be on a table so the sensor is unlikely to be set off by animals. I am looking for a small discreet sensor that can be concealed within my display and can trigger a 10second message and flashing L.E.D. lights for 10 seconds simultaneously. It would also need to conceal the battery, speaker and circuitry, so as small as possible while meeting my criteria is needed.
If I bought a ready made unit that will give a 10 sec. message, triggered by a PIR sensor, would I be able to attach flashing L.E.D. lights and use the same circuitry?
If not what would I need to make it work?
If I needed to change the PIR sensor as it only works well in dark or poor light to a more efficient PIR sensor, would it be easy enough to change and use the same circuitry?
I am sorry I am so naive about these things, but I am an absolute beginner who has probably bitten off more than he can chew. I am grateful for any ideas or suggestions that may help, given my situation and needs.
