I have a load cell with a 1.785mV/V output that I would like to amplify and connect to a data acquisition system. The load cell may have been damaged and now has a very large (relative to the output level, at least) offset at zero load, of around 135mV. Assuming that the load cell still has a linear output of 1.785mV/V above this 135mV offset (it
appears to in my limited testing) what is the best way for me to subtract the offset prior to amplification? The load cell uses a standard bridge:
I built a test circuit (Crude schematic attached) that feeds the bridge output into a unity gain differential amplifier, which is then fed into an inverting summing amplifier along with a trimmable (and op-amp buffered) DC voltage that cancels the offset and has a gain of 100. This works and gives me the expected (inverted) output.
Is there a simpler/better way to achieve the same result?
P.S. In reality I can probably feed the signal directly (with no amplification) into my DAQ system and correct the offset in software, and my load cell may in fact be NFG, so the circuit design is more of a learning exercise.
