Hi Richard,
Thank you for your reply.
Based on your reply and Tim's it would seem that a charge-pump converter is the way to go.
So you are converting digital to analog so you can feed it into an analog to digital converter?
Yes, I know this sounds stupid and is going to loose some accuracy but unfortunately I don't have control over the input side.
The input of the existing product was designed to be connected to a sensor that outputs a varying voltage.
I am wanting to emulate this sensor.
