i am want to see how components react to 30 amps of current and i have used ltspice, multisim, and Circuit Wizard for this but i had noticed that if i place a dmm/ get the voltage at any node it will show 30kv useing an amp source of 30, but if i use 17vdc there is no amps/ very little.
so what is the correct way to simulate this?
PS: im looking at making a variable 17VDC 30AMP ( minus of coarse all the voltage drops from the components. ) CC/CV bench power supply from an old rv inverter transformer that is 17VDC 30AMP.
