Right, I think I'm following you, in short terms I need an oscillator with a relatively short duty cycle and follow this logic?
Gate To Be Turned Off when VOUT is greater than VREF+Hysteresis -OR- Current Sense is greater than Current Limit
Gate to Be On when VOUT is less than VREF-Hysteresis -AND- Oscillator Pulse is High -AND- Current Sense is less than Current Limit
Thus I need a flip-flop as you described to prevent the gate turning off when the oscillator pulse is low, the oacillator should only be used for the logic of turning it on, not turning it off.
It should be reset dominant, so "if CS > CL, gate off" takes priority. Also, CL should be controlled by an error amp (which can be an op-amp with compensation, or if you must... ADC --> PID register --> DAC). But that's more or less the right idea.
They give the logic diagram of course, so if you don't mind reading RTL,
http://www.ti.com/lit/ds/symlink/uc3843.pdfI also think I know what you mean about the source being grounded, that's how I always picture P devices, I imagine them like an N device but with their view of the world inverted, they see the +ve rail as ground and the -ve rail as a negative supply voltage.
Good, that's exactly what's going on.
Unfortunately, due to the established system in place for these kind of devices, the eventual load is always common to the supply negative (the load is put into the mouth using a metallic mouth piece which is electrically common to -ve due to the power supply also being mains earthed to the -ve to prevent a psu failure from electrocuting someone's face) so using N channels is not impossible, but far more tricky.
I'd be more comfortable with 8kV medical isolation... or better yet, a plastic appliance.
Not sure if there's regs specific to oral appliances. Sounds medical-ish though. Yeah, grounded is better than not, but not ideal...
EDIT:
To help me visualize logic, I often try to write them as computer code, obviously this would be impractical without a 100mHz processor and fast ADC,
Well, it wouldn't be terrible with a >10MSa ADC and an FPGA. But it's so vanishingly little logic that it's of course pointless (it synthesizes to a single R-S flip-flop, maybe with some AND/OR/NOT stuff to resolve the specific conditions). Implementing it in software would be...grotesque...
Another problem is I somehow have to detect the load resistance. I currently do this by applying 5V to the load through a 220 ohm resistor and an npn transistor (to prevent the actual vout getting back into the resistance sensing circuit) and then using an opamp to amplify the node between the two. This circuit is switched on and off by the MCU as it doesn't need to be constantly sensing it, only once every 3 seconds or so and then it's only on for a few milliseconds. Now this becomes more complex, the vout has a cap between it and ground, so this approach won't work,
Nice thing about building a current-mode circuit is: if you tell it to deliver no current, it'll happily just sit there, off...not delivering any current! You can manipulate the current limit or voltage reference signals at will (say, by summing an error signal from a DAC, or analog switches to gate in something else), so you don't need to diddle around with junk like that -- it all stays nice and neat and in the same loop.
Given the cap, you will of course want to pulse it for on the order of a millisecond, then leave it off until the next test. The current doesn't need to be much (you may even have trouble adjusting it low enough), but whatever you get is fine, as long as you know what it is, and it's not dangerous or anything (an open circuit load still takes time to charge the cap, and you can probably detect that easily enough with a well-timed ADC sample).
Argh, the problems are too big. I have no idea how these other manufacturers manage to produce a board that can do everything I want and make it so small. There's a board out called an SX350, it can output 50W to a load of as low as 0.2 ohms and it measures less than 30mm square. It can sense resistance, it has ground common load, current limiting. Hell, just the size of the shunt resistor alone to handle shunting to a 0.2 ohm load would be crazy, not to mention the amount of power I'd lose through it. *sigh*
That sounds quite reasonable. If size were absolutely important, I could probably do better. But there's nothing unreasonable about a PCB that size, assuming you can get the heat out of course. It just seems overwhelming because you have all these jagged, disparate pieces in your mind, still coming together.
