Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Binary counter troubles
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Binary counter troubles (Read 2200 times)
MechEng87
Contributor
Country:
on:
October 01, 2016, 01:23:08 am »
Hello everyone, I am new here and love the forum and the eev blog YouTube channels. I am working on a project for a counter that has me troubled. I am using g a 74ls163 binary counter and I am trying to get it to stop could time g at 9 and reset. I have done some looking online e and tried everything I can think of to get it to reset after 9 instead of counting all the way up to 15 then going g back to 0. I hope this isn't too basic a query but if anyone can help I'd appreciate it. I am working on building a light gate timer for velocity measurements.
Logged
ataradov
Super Contributor
Country:
Re: Binary counter troubles
Reply #1 on:
October 01, 2016, 01:47:27 am »
9 is 0b1001 (8421), so your stop signal is: (1 & 8 ) & ~(2 | 4). You can obviously rewrite this into whatever logic gates you have at hand. In this case you need 2 AND gates and one NOR gate.
Logged
Alex
MechEng87
Contributor
Country:
Reply #2 on:
October 01, 2016, 01:58:35 am »
Ok, that's kind of were I was headed but so far nothing is working the way I expect. I tried putting a diode and gate with Qa and Qd as the inputs that would reset the timer on the next clock cycle but no luck. Is a diode AND gate appropriate? I'm using all 5 volt logic levels.
Logged
ataradov
Super Contributor
Country:
Reply #3 on:
October 01, 2016, 02:01:41 am »
You can make AND gate out of diodes, but AND gate alone is not enough here. And it is obviously better to use real gates for a real project.
Logged
Alex
KerryW
Regular Contributor
Country:
Reply #4 on:
October 01, 2016, 03:38:29 am »
Actually, if you just NAND Q0 & Q3, you would get a Reset pulse at 9, 11, 13 and 15, but since it would reset to 0 at a count of 9 it wouldn't matter.
Logged
One accurate measurement is worth a thousand expert opinions
- Adm. Grace Hopper
ataradov
Super Contributor
Country:
Reply #5 on:
October 01, 2016, 03:53:53 am »
Quote from: KerryW on October 01, 2016, 03:38:29 am
Good point. In that case diode AND should work just fine.
Logged
Alex
danadak
Super Contributor
Country:
Reactor Operator SSN-583, Retired EE
Reply #6 on:
October 01, 2016, 09:48:50 am »
Do you have a race condition or not meeting PW for the reset signal ?
A scope can help here, and look at datasheet to create a timing diagram to
see if you are not meeting chip timing.
Regards, Dana.
Logged
MechEng87
Contributor
Country:
Reply #7 on:
October 01, 2016, 04:36:45 pm »
Got it! Thanks for everyone's help, I used an AND gate on q0 and Qd then fed it through an inverter and it works perfectly. I will just use a NAND gate as KerryW suggested. Thanks again everyone. I will post pics of it when I get the rest of the circuit going
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
