I hope I'm in the right place -- there are at least three different subforums of this place that I could technically fit this thread into. If I'm in the
wrong place, I would not object to being moved.
I have attempted to construct an Arduino project called a "Zorkduino". Info about the Zorkduino is here:
https://github.com/rossumur/ZorkduinoMy configuration is very similar to the recommended Zorkduino circuit, but I have made some deviations. A proper circuit diagram will be posted, below, shortly, along with at least one photo of the gloriously awful rat's nest I've grown inside this thing -- but for now, text will have to do. The deviations are...
(1) I am using a CH340-type Arduino Nano as the 'brains' of the circuit. Info about these specific Nanos,
here.
(2) I am powering the entire contraption from a dual-rail 5v/12v supply, specifically a LaCie power brick. I have tried two different "sizes" of brick, as is detailed in the explanation (further below) of what's gone wrong.
(3) I have integrated a direct connection to a composite-input, 480x234-pixel-resolution, seven-inch LCD. This LCD requires 12v for power (unlike the rest of the project), hence the dual rail supply and messing about with Kycon connectors. (Note: in this case, "direct connection" does
not mean that I skipped the two required resistors. They are present and accounted for.)
(4) The 5v rail is switched immediately after the Kycon connector and before any componentry other than the power brick. The 12v rail is
not switched, as the LCD has a "soft" power button integrated that drives that function.
(5) The audio goes directly to a piezo can element (the little black can type, commonly seen in PC motherboards and the like) with no resistor or capacitor in between it and the Arduino.
(6) The entire assembly is mounted into a Solidtek ACK-595 keyboard, with the LCD on laptop hinges. It's not entirely pretty, but it's functional and I sort of like the kludge aesthetic (to the extent that such exists).
The problem, unfortunately, is that I don't seem to have any video out. When the 5v rail is switched off (just after entering the chassis), the video output is
probably trying to render a "no signal" screen; however, the output is severely distorted. Switching on the 5v rail, 'straightens' the screen (rendering it normal and usable) but there still is no recognizable signal being picked up. (Photos will follow shortly.) Mind you, this is with a
standard LaCie brick, 5v/2.0a 12v/2.2a. If I sic a LaCie "Bigger Disk" brick (5v/4.3a 12v/3.0a) on it, the brick just power-cycles.
The only thing I've been able to come up with is that maybe, because only the power side of the 5v rail is switched, and the 5v ground goes into the LCD as the signal ground, that maybe there's a short between power and signal grounds on the :CD controller and it's backfeeding something...? That seems a little shaky to me, but I don't know enough to entirely dispute it.
Photos and schematic, in my next post.
Any help or advice able to be given, is welcomed and requested. (I'm not here to whine.) An odd request: if you can't help, better to tell me than to just move on -- I have a bad habit of assuming I've been ignored, when the shadows get real long and I've not had so much as a peep out of anyone...
