Author Topic: BLDC controller with fast response  (Read 1412 times)
Offline ZeroResistanceTopic starter
« on: January 19, 2018, 05:14:53 pm »
I have a BLDC controller that I use to control a BLDC motor. The controller has 0 to 5V speed input and the speed of the fan is set based on this speed input voltage. What i have noticed is if I give a step input say 1V to 2V the controller responds only after a delay of 0.3 to 0.5s, that is the speed of the fan only starts to change after 0.3 to 0.5 seconds.
1. Is this a normal delay for a BLDC controller?
2. Are there controllers that can respond quickly within to the input speed signal?
3. I have heard of Gecko drives for Stepper motor are there any similar companies that make drives for BLDC motors?
TIA
Offline Benta
Re: BLDC controller with fast response
« Reply #1 on: January 19, 2018, 09:11:47 pm »
No, it's not normal, BLDCs respond as quickly as brushed motors. For whatever reason, your controller has a delay. Try another one.
The following users thanked this post: ZeroResistance
« Reply #2 on: January 20, 2018, 03:43:12 am »
Are there any reputed BLDC controller manufactureres like Gecko, Leadshine are for steppers?
Offline Belrmar
« Reply #3 on: January 20, 2018, 10:26:34 am »
actually texas instrumets makes some pretty good bldc controllers
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #4 on: January 20, 2018, 10:54:58 am »
For fan type motors there are a lot of options - Microchip and Onsemi do several, I think Allegro also.
Delay may be connected with the sensorless feedback algorithms, and that for most fan type applications you don't generally want the speed changing frequently so they may have some internal filtering
Day Job: Mostly LEDs
« Reply #5 on: April 06, 2018, 11:03:24 am »
I see that most controllers for BLDC motors are microcontroller based and not is this the right way to go? Are there any standalone controllers available for fan type  motors?
« Reply #6 on: April 06, 2018, 04:14:41 pm »
Yes, lots (dome use embedded MCUs but the user doesnt havw access) search bldc on digikey and filter by controllers, 3 phase
