Years ago I designed a range of very high power audio amplifiers, intended to be rack mounted.
The air flow was from front panel to rear panel (air was flowing inside the rack) because we did not want to have an hot front panel.
We tested, with the same fan, both solutions (blowing-in and sucking-out) , and the result was that blowing-in was better, for the following reasons:
1) the cooling channel was cooler (about 5 degrees lower), because cool air is denser than hot air, and what cools is air mass, not air volume.
2) the fan temperature was lower, increasing fan's operating life
3) a fan spinning in hot air seem to increase her speed, resulting in higher noise.
The problem was that blowing-in required mounting the fan just inside the front panel, and panel aesthetic was compromised (there was no space for an internal tunnel, and the fan was almost visible) .
Another problem was that the fan's noise was coming from the front panel, and this was objectionable.
We opted for the less than optimum solution: an higher speed fan sucking air out from the rear panel (noise was inside the rack, and less audible, and panel design was simpler and more elegant).
But the industrial version of these amplifiers, where aesthetics was less important, was designed the correct way.
