I would like to build a light-weight circuit that, from 1 or 2 1.5V AA batteries is capable of generating a 2-3 seconds impulse in the 12-40V range (the higher, the better). Is there a very easy way of doing that? I saw many boost converters on the net, but they either output a lower voltage, or they are very complex.
Ideally, the impulse has to be driven by a switch and should not empty the batteries in a single shot (I would like, let's say, a dozen of these impulses at least)...
Thanks a lot in advance!!
Rob
