Hi EEVblog.
I have a lithium cell connected to an SX1308 boost converter setup, with 10uF ceramics on input and output, and a 100uF eletrolytic on output.
The cell is also connected to a MIC5504 3.3V LDO regulator, with the 1uF caps on input and output as stated in the datasheet.
The regulator works when the converter is off, but as soon as it's turned on, the regulator goes crazy, and spits out the input voltage. .
I figure it's a noise issue, but how would i separate the regulator from the converters noise?
Hope you can help.
