But what about advantage of "center tapped transformer + two diodes"
On the one hand less diodes means better efficiency and less heat. On the other hand it requires more copper in the transformer.
This rectifier topology is commonly used in SMPS supplies (push-pull, half-bridge, full-bridge topologies), since at high frequency the transformers are small, and copper usage is not a concern.
"center tapped transformer + brige"
It is useful for dual power supplies, since center tap is half voltage point. You will find this rectifier for example in audio amplifier or linear lab power supplies. Or even in power supplies of PCs to generate +12V and -12V rails (with unsymmetrical rectifier, 2 large Schottky diodes for +12V rail and 2 small diodes for -12V rail).
