protected mosfets. these sense overcurrent and sht themselves off. custom part made by infineon. not avaialble on the market
Not exactly true:
Note, that those devices have tab connected to one trace, first lead is a single signal, and all the remaining 5 leads are connected to one fat trace. High power protected switches usually have more signal leads for diagnostic purposes (like external current-mirrored current output). Those are N-MOSFETs in7-lead packages. They do that because single leads in TO263 cannot handle such large currents. They don't do that for P-MOSFETs.
This must be from a 12V passenger car, because in 24V vehicles (like most trucks) power devices are typically rated for 55V and higher.
P2N04L03 = IPB160N04S2L-03
**n0402 according to Infineon's naming convention will be a 40V 2mOhm N-Mosfet. TO-263-style package means it will be IPB series. I would guess one of those:
IPB180N04S3-02
IPB160N04S4-02D
Infineon's naming format for automotive mosfets is following:
IPabbbcddee-ff
IP- infineon power mosfets
a - package symbol (B = D2PAK)
bbb - current rating
c - N for N-channel, P for P-channel
dd - rated voltage divided by 10
ee - semiconductor technology. S2 = optimos, S3 = optimos-t S4 = optimos-t2
ff-Rds in miliohms.
As for the high-current shunts I would bet on custom stuff from Isabellenhütte.
