I dunno, I use ProbeMaster probes, and even with them, I find the U1252B to be maddeningly slow.
(The absolute gold standard in my lab is the Keithley 2015, whose continuity tester is just amazing. It actually makes a Fluke 87V look sluggish!)
I think you've accidentally swapped the terminology of latching and non-latching, nanofrog. Non-latching means it's literally an analog comparator circuit with an oscillator. They react instantly, but scratchy, and can miss intermittent continuity.
A latching continuity tester uses circuitry to "hold" a pulse of continuity longer than it actually lasted, so you don't miss it. (Some do the opposite, too, of lengthening a lapse in continuity.) But they also have to use some kind of noise rejection so as to not beep constantly, and this is where the quality of implementation shows. The Fluke 87V, Keithley 2015, and U1252B all have latching continuity, but the first two work great, the third is awful.
Indeed, many cheap meters have latching continuity that's borderline OK, such that the included probes make it work poorly, but using nice gold-plated makes the continuity test come to life, so to speak. (Uni-T is like this.) Gold probes also make non-latching continuity testers WAY less scratchy. In contrast, really good continuity testers like Fluke and Keithley are so good they can actually mask the low performance of cheaper probes.
