Hello,
I have the circuit attached, with an small 220v motor, it draws 300mA. after 2 months and about 500 cycles of 40 sec one of the BT138 started to fail ( the channel started to go on like a flicker, when I put a light bulb on it flashes from slow to faster).
control is done from a microcontroller.
I read it might be a snubber problem, but this one works for 2 months or so..
and the bad part is that when it fails it stays on and the motor runs forever and the microcontroller doesn`t sense that and can`t stop it either.
regards,
Cosmin
