Hello,
I got my board in for the MPPT controller I'm building, and I got all the parts on it, and for the most part it works perfectly, but I am having a very strange issue with it.
For any input voltage higher than around 7V, the buck converter initially outputs .6V no matter what the input is, but then if I dip the input below 7V, even for just a fraction of a second, something kicks in and it just starts working like it's supposed to, even if I raise the voltage back up above 7V.
My gut is telling me that it's a problem with high-side mosfet not getting boosted correctly. Maybe the boost capacitor can't charge quick enough?
The picture of my schematic is attached, as well as the datasheets for the mosfets and buck controller.
Any advice on how to isolate the problem would be greatly appreciated.
Thanks!
