Hello. I know this is a bit dated thread, but I found it over google, and I thought I'd just ask here rather than starting a new thread.
I am also working on a DC/DC buck converter, and I was wondering about the voltage ratings of output caps. The texts and application notes I've read usually state that the buck input capacitor should have its voltage rating about twice the maximum input voltage. For example, if I'm using 24V as input, I should select 50V input filter caps. This is to be on the safe side due to possible voltage spikes during the mosfet switching phase. But none of the texts that I've read mention anything about the voltage rating of the output caps. So I'm wondering in confusion what's the rule here. Should I go for output caps with a voltage rating twice the max
input voltage? Should I go for a voltage rating twice the maximum
output voltage? Or should I go for other value??? Is there any relation between max input voltage and the output cap voltage rating?
