Last time 888 went on sale at my Fry's for 69.00, it was for in-store, only. This rules out most of the country.
1. Weller WLC100: The Weller is variable power, which is not nearly as helpful as temp-control.
Without digging into it, I also would assume the tips are not compatible with more "serious" wellers; i.e., I would ASSUME tip selection and availability is bad.
2. X-tronic: I have used the Xtronic 888 style soldering iron in the past. I am not impressed with their clone of the Hakko handpiece. The plastic and molding is not high quality. This was obvious to me from the start, even before it cracked in two. The heater was undersized, as well. If you really like the station for other reasons, plan on buying and swapping out the plug on a replacement handpiece, IMO.
3. Aoyue 469: It looks like it might take hakko T18 tips(?), but the variable power makes is as much a non-starter as the Weller WLC100.
4. 862D+: I do not like combo stations. Personally, I do not like the diaphragm pump hot air, at all. Max air flow is very low, the air hose for the hot air is large and inelastic, and the stations are very large and bulky. It is more versatile to have them as separate (and smaller) units, at any rate.
If I wanted to buy a complete soldering station for under 50.00, I would consider a temp-controlled station, only. Perhaps a
1. T18 compatible clone, such as 939D, 937(D), 936
2. T12 compatible clone
