This might be a very basic (and even stupid?) question, but need takes me into an unfamiliar area. I must build a small Arduino appliance into a handheld enclosure, and the results must be reasonably professional looking. I'll be building 8-10 units, and while I could be required to generate another handful I do not expect to build them again. The project is based around Arduino Micro and uses USB output, a serial LCD, and 5 switches... three momentary and two persistent state. One of the latter is a power switch, the other is an input switch.
I've been researching various aspects of building a project in a good-looking enclosure -- my projects have historically been a pile of wires on a piece of plywood -- and have done the following:
- selected an enclosure with 9v battery bay
- arranged with a machine shop to do whatever I need to it
- found an inexpensive source for a graphic overlay, providing a clear viewing window for the LCD
What I have not found is any resource or information about how to effectively mount the components in this situation. The enclosure has mounting bosses (terminology?) on both the top and bottom halves. I assume a few things:
1 - that I want to fabricate a piece of perf board that screws to the top's bosses, and mount my LCD, switches, and Micro to this board
2 - that the Micro mounts near an edge such that its micro USB connector pokes through a matching hole in the front or side of the enclosure
3 - that I use tactile switches on the perf board below matching holes in the top, and there's some sort of plunger that floats above them
Of particular concern is that the LCD (standard 1602A) is thicker than the mounting bosses are tall. If my enclosure hole is the size of the viewable area, I need to space the perf board off the bosses to create additional clearance. Is it preferable to machine the case such that the bezel also protrudes through the case top? I have not checked thickness of the case front to see if it ends up flush or not.
I would greatly appreciate any feedback on my circumstance, plus any pointers to reference materials on the internet or in print covering these issues. Also very interested in thoughts on what switches and/or plunger things, since I've never used tactile switches and have no familiarity beyond their existence.
My immense thanks in advance for any help!
Jason
