I like to build my code with zero warning/error. Warning in some cases may be unavoidable but can be most of cases.
1. I have written a bare minimum code as below.
void setup(void)
void loop(void)
2. On building code I have seen warnings in three files as below:
HardwareSerial.cpp.o
C:\Program Files\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp: In function 'void store_char(unsigned char, ring_buffer*)':
C:\Program Files\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp:98: warning: comparison between signed and unsigned integer expressions
C:\Program Files\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp: In function 'void __vector_18()':
C:\Program Files\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp:127: warning: unused variable 'c'
C:\Program Files\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp: In member function 'void HardwareSerial::begin(long unsigned int, byte)':
C:\Program Files\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp:368: warning: unused variable 'current_config'
C:\Program Files\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp: In member function 'virtual size_t HardwareSerial::write(uint8_t)':
C:\Program Files\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp:467: warning: comparison between signed and unsigned integer expressions
Stream.cpp.o
C:\Program Files\Arduino\hardware\arduino\cores\arduino\Stream.cpp: In member function 'bool Stream::find(char*)':
C:\Program Files\Arduino\hardware\arduino\cores\arduino\Stream.cpp:78: warning: deprecated conversion from string constant to 'char*'
Tone.cpp.o
C:\Program Files\Arduino\hardware\arduino\cores\arduino\Tone.cpp:119: warning: only initialized variables can be placed into program memory area
3. Warnings in HardwareSerial.cpp , I have removed & file I have attached.
On top of attached file I have also mentioned how I have removed those.
Any comment/suggestion on that whether I have done right or wrong?
4. Warning in other files I don't understand. Anyone else can help on that??
5. I am not very legalese person, so don't if editing these files violates anything?
6. I have also attached 3 original files in which there were errors.
