objective: to measure/verify my 1Mohm input differential probe output accuracy and CMRR at greater resolution, my ±10V FG is not enough.
HV-FG V output: Mains voltage ±330V (240Vac) capable of driving 1K, 10Kohm or 100Kohm load. whichever is possible, lower ohm (hi wattage) is better.
HV-FG F output: 50Hz - max Hz. max Hz will depends on simplicity of the project. if its up to me i'll put 100MHz there, but for the start i believe 300KHz up to 2MHz or 10MHz should be feasible?
distortion spec: close to none. for the start, if i can get a square pulses instead of pure sine, then thats workable or good enough i think. as always, pure sine is better, if the circuit's complexity is managable.
idea: i have two ideas in mind (attached picture).
idea 1: is using mosfet or bjt to switch the mains voltage. the control is from normal ±10V FG to optocoupler controlling the mosfet gate. the problem... my PC817 opto only rated at 35Vce, how do i make a circuit to accomodate the opto on the hot 330Vdc side?
idea 2: is using step up transformer. this requires more solid 4 quadrant PSU to drive the Tr primary rather than the normal 50ohm FG which luckily i have built on smaller scale (around 10W, 2MHz BW) sometime ago. the problem is, as i connected the 4Q-PSU to the primary, i got very nasty ringing on both side probed with DSO. do i need extra circuit to avoid this ringing? a snubber maybe? can i use the same snubber structure as usually found in SMPS flyback designs? any example more proper for my application?
hope you people can help thanks.
