Author Topic: 555 timer issue  (Read 2711 times)
Offline IvoSTopic starter
555 timer issue
« on: December 22, 2013, 09:25:16 pm »
I am having problem with 555 timer. Everything looks nice when channel is put to DC coupling, pic #1.
When I switch to AC coupling (pic #2) on my Rigol scope, I see nasty non-square like waves. I am not sure what's going on. What I don't understand is the falling edge goes to -8.8V. I would expect it to be around -5V when AC coupled, kind of symmetrically distributed from the center 0V point, my PSU is set to single +10V. Why don't I see top and bottom edge flat anymore? Any idea?
Online Zero999
  • 0999
Re: 555 timer issue
« Reply #1 on: December 22, 2013, 10:06:27 pm »
It's what you should expect to see when you switch to AC coupling. The capacitor and resistor on the 'scope input form an integrator which causes the classic exponential decay when the capacitor charges and discharges. If you increase the frequency of the 555 to something like 1kHz, the weird curves and spikes will disappear.
Re: 555 timer issue
« Reply #2 on: December 22, 2013, 10:25:54 pm »
I thought that pin 3 output is just a flip-flop output and therefore should still maintain reasonably square wave. ?
Offline grumpydoc
Re: 555 timer issue
« Reply #3 on: December 22, 2013, 10:47:55 pm »
Nothing to do with pin 3's output.
Hero999 is right - you are seeing the effect of AC coupling on what the 'scope shows - usually when you switch in AC coupling the lower frequency response tails off below about 10Hz and this will affect the display of slow square wave signals.
Offline M0BSW
  • Left this site 2013, they will not delete it ????
Re: 555 timer issue
« Reply #4 on: December 23, 2013, 07:46:48 pm »
I use pin 3 as a trigger pulse output for scope, showing the triggering pulse on the scope, which I learned from a W2AEW video, and I've used it on several other projects . I agree with the others from my limited experience.
« Last Edit: December 23, 2013, 07:50:03 pm by M0BSW »
no one would or will tell me how to delete this account
Re: 555 timer issue
« Reply #5 on: December 23, 2013, 09:17:57 pm »
Thanks guys. Had no idea that scope input can mess it up to that extent. So there is nothing wrong with the output and the waves are still reasonably square. I was surprised how quick rise and fall edges were. If I remember correctly the rise time was 130ns and fall time around 15ns in my slow speed configuration.
Online Zero999
  • 0999
Re: 555 timer issue
« Reply #6 on: December 23, 2013, 10:57:35 pm »
It's a high pass filter so the high frequency parts of the signal (rise and fall) are not changed, only the low frequency parts (where the signal is high or low for a long period) are suppressed.
