Correct, and works well. Adds a bit of capacitance to the unit and a little leakage, but when compared to the expected results it will only make a small difference with any capacitor under 1uF and with an ESR over 1k, so basically does not make any difference to your usual sub 1 ohm capacitor over 100uF. I used 1n400x diodes as they were to hand when i built mine years ago, and it probably will survive albeit the diodes will fail most likely short circuit.
