I am sure that the ready made off the shelf modules would be tested and working just fine
well, believe it or not, building them is much cheaper than buying them specially I am going to build almost 8 (other 4 for bldc)
the idea is to be able to build cnc prototype as cheap as possible (one that I can do something with
) using some old dot matrix printer motors to try to understand the difficulties that I might face
after successfully be able to run it without major problems, I will buy new stronger motors to build a bigger one
I have most of the parts already, only the drivers not available
so I want to have good driver from the beginning that can handle smaller and bigger loads without the need to build new one for the other bigger motors
I don't know how bigger I will buy later in the future (that's my problem now)
maybe I am over thinking about it, but that's the way I am seeing things right now
can I use LTSpice to simulate h-bridge built with mosfet and being drived with gate driver ics
sorry never used it before, maybe it is a good idea to use it(hope it is easy to learn and quick)
