Hi all,
I'm trying to route some 90? differential pairs for some USB 2.0 High-speed data lines. To calculate the trace width/spacing, I used SaturnPCB. However, when using EEWeb's impedance calculator, I get much different values. I'm not sure which calculator to trust. Should I just go with SaturnPCB's values and pray it works? The difference seems pretty severe (10%) but I guess would fall within the 25% tolerance, so it might be OK either way--I don't know.
I thought about calculating it myself manually, but when I looked at the equations I was a bit lost...
The board stack (OSHPark) is as follows:
- 1 mil solder resist
- 1 oz copper (1.4 mil)
- 6.7 mil prepreg
- 0.5 oz copper (0.7 mil)
- 47 mil core
- 6.7 mil prepreg
Any help is greatly appreciated!
