Probably, you can put a link between 0V on one and 30V output on the other and measure the two outer points with a meter, on mine if I set it to two 12V outputs I get 24V, but they are isolated supplies.
another option if you only want a bit extra is to use a boost converter, you can get these from Ebay quite cheap if you only want one.
