If the colours change at wider angle, then of course the viewing angle is down to the LCD itself, if it just appears very dim, then the narrow viewing angle is intentional for power saving, and possibly security.
Often displays for laptops/tablets use prismatic films that focus the backlight to a narrower angle. This means you can use less power for the backlight to achieve the same brightness when viewing it directly in front. They use really narrow prismatic films for things like ATM's, where security is an obvious concern and you don't want people looking over your shoulder, for the most part though its far reducing the backlights power consumption.
So again, as its very likely to be a TFT which already have quite good viewing angles, rather than replace the display, you may wish to prize it apart and remove a couple of films - there will be several: polarized diffuser, prismatic films horizontal/vertical, and possibly another diffuser on top of that. Its an arse to do as there will likely be lots of tape around it, but at least its a reversible mod.
