Author Topic: can i run a 13.8v cb/ham Transceiver on 12v  (Read 3816 times)
Offline rickselectricalprojectsTopic starter
« on: April 18, 2015, 02:31:26 am »
hi everyone!
i was wondering if you could run a 13.8v ham/cb transceiver on 12v. i know it would still work but i was wondering if it would draw to much current on 12v and damage the transceiver and if it would affect performance. sorry if this question sounded stupid but i am only just getting into ham/cb radio.
thanks everyone! :-+
Offline Vgkid
Re: can i run a 13.8v cb/ham Transceiver on 12v
« Reply #1 on: April 18, 2015, 02:43:38 am »
make and model, what does the manual say.(should be ok I guess). after all 13.8 is the alternator charging voltage of a 12v battery.
« Reply #2 on: April 18, 2015, 02:54:38 am »
+- (plus or minus) 15% but i was wondering if it will decrease performance
Offline Psi
« Reply #3 on: April 18, 2015, 02:55:17 am »
na, will be fine.
It will have been designed for 13.8V because that's the float charge voltage of a 12V lead acid battery
Therefor we can assume it will be fine with a flat 12v lead acid. ~10.5 - 13.8V will be the intended voltage range.
In general a lower voltage doesn't damage things.
An exception is badly built switchmode power supplies that don't auto cut-off at low V and instead try to run with way to much current flowing through the components
« Last Edit: April 18, 2015, 02:57:47 am by Psi »
Offline miguelvp
« Reply #4 on: April 18, 2015, 03:06:48 am »
Think about it this way, you don't have to have the car running to use the cb radio.
