Author Topic: Can I use 100 mhz probes on a 20 mhz analog scope?  (Read 12576 times)
Offline vigsgbTopic starter
« on: February 26, 2014, 04:52:48 am »
I seen Dave's video on getting an oscilloscope for 50 bucks and managed to procure a two channel analog 20mhz one for 60 bucks and was wondering if I can use 100 mhz probes on it.
Offline sacherjj
Re: Can I use 100 mhz probes on a 20 mhz analog scope?
« Reply #1 on: February 26, 2014, 04:54:06 am »
You can use high rated probes on lesser scope with no problem.
Offline codeboy2k
« Reply #2 on: February 26, 2014, 06:32:24 am »
Sure you can use a probe that's better than your scope, but just make sure you are using 100 MHz probes, not 100mHz probes.   :-+
Offline Legit-Design
« Reply #3 on: February 26, 2014, 06:50:29 am »
You could even use probe that is "worse" than your scope, then you just need to be aware of the attenuation.
Online kripton2035
« Reply #4 on: February 26, 2014, 07:53:29 am »
I just guess it would be difficult to find less than 20MHz probes ?
Offline grumpydoc
« Reply #5 on: February 26, 2014, 08:03:00 am »
Most probes in x1 mode will be less than 20MHz
The BNC to alligator clip things probably less than 1MHz
Online G7PSK
  • It is hot until proved not.
« Reply #6 on: February 26, 2014, 09:08:42 am »
You might find that higher band width probes will not adjust correctly for a lower band width scope, very often high bandwidth probes are 17 or 10 pf whereas probes of low bandwidth are up to 40 pf this is due to the scope matching requirements.
Offline 6E5
« Reply #7 on: February 26, 2014, 12:28:36 pm »
Dave has a very nice video on why 1X probes have such reduced bandwidth
« Reply #8 on: February 27, 2014, 12:47:22 pm »
   I will have to watch that video.
Offline w2aew
    • My YouTube Channel
« Reply #9 on: February 27, 2014, 02:31:44 pm »
As mentioned previously, just be sure that the probe compensation adjustment will cover the input capacitance of your scope.  If not, then your frequency response will suffer.  For more detail, you might want to review my video on the basics of 1x and 10x probes:
FAE for Tektronix
« Reply #10 on: February 28, 2014, 11:06:09 pm »
I got a copy of the service manual and operators manual for my scope and found the impedance and order the probes.  Thanks for all the help from everyone.
Offline w2aew
« Reply #11 on: February 28, 2014, 11:19:02 pm »
The input capacitance is almost always printed on the front panel, right next to the vertical input connectors.
FAE for Tektronix
« Reply #12 on: March 01, 2014, 06:37:52 pm »
I noticed that after watching several more videos.  I liked the videos you have on your channel.  Learned a lot of newbie stuff from them.  Thanks for making them.
Ironically my scope fell through for 50 bucks right after I ordered my probes but I got a 40Mhz  one for 100.00 and the probes I got will work great.
