Author Topic: Can I use 1:1 passive probes with 64pF shunt capacitance with a 1054z?  (Read 1493 times)
Offline julian1Topic starter
Does 64pF, imply actual compensation adjustment anywhere from 10pF - 64pF ?
The probes are these,
http://www.keysight.com/en/pd-1000000977%3Aepsg%3Apro-pn-10439A/11-2m-miniature-passive-probe?cc=US&lc=eng
If not - then can I change the capacitor trimmer?
Offline tggzzz
Re: Can I use 1:1 passive probes with 64pF shunt capacitance with a 1054z?
« Reply #1 on: February 21, 2017, 09:01:08 am »
It means the tip capacitance that loads your circuit is 64pF. *1 probes don't have a frequency compensation trimmer capacitor.
They can be used with a 1054Z scope, with the standard performance limitations.
The following users thanked this post: julian1
Offline danadak
« Reply #2 on: February 21, 2017, 12:56:23 pm »
Of course you have significant circuit loading, at 1 Mhz Xc ~= 2.5K
ohms, quite low.
Completely out of the question to probe a crystal oscillator circuit
for example, at the crystal.
Regards, Dana.
