Also, not sure if it was mentioned, you're using 7400 series devices. The letters after the '74' indicate the technology used. LS is very old and probably hard to find, so look for 74HCxx or 74HCTxx.
'HC' will work with ~3-5.5V, HCT is 4.5-5.5V, so 5V only. If you're using 5V, either will work and are far more accessible than the old LS series.
The 'xx' is the device type. Because HC, HCT, LS F, ACT etc.. are basically the same devices, with the same pinout, CAD/schematic software will omit them, leaving you only with '7408' of example.
Exit: just noticed this was already covered! Apologies to Ian.M.
