It's actually pretty standard for smaller capacitors.
The value is also often just two digits long, in which case it's just the value in pF, unless it's a polarised capacitor, in which case it'll be in µF. You may also see things like 4p7, in which case the p replaces the decimal point so it's 4.7pF.
