Author Topic: Passive full-wave bridge rectifier V_output > V_input ?  (Read 2993 times)
Offline raff5184Topic starter
« on: February 19, 2018, 09:06:56 pm »
Hi all,
I realized a full-wave bridge rectifier with BAT54 diodes. My input is a 700kHz sinusoid 10V peak-to-peak, while the output open circuit is a DC voltage higher than 5V (that is more than 10/2 V) which is not expected.
Where am I losing power? Is it because the input is too high?
I also did a simulation in SPICE and the DC value is actually 4.8V as expected
Full-wave bridge rectifier: https://www.allaboutcircuits.com/textbook/semiconductors/chpt-3/rectifier-circuits/
BAT54 datasheet: https://www.diodes.com/assets/Datasheets/ds11005.pdf
« Last Edit: February 19, 2018, 09:11:39 pm by raff5184 »
Online newbrain
Re: Passive full-wave bridge rectifier V_output > V_input ?
« Reply #1 on: February 19, 2018, 11:44:32 pm »
Of course, the output voltage is supposed to be lower than the peak Vin...
But:
How are you measuring these voltages?
Scope or DMM? Or something else?
If DMM, consider that 700kHz might be well outside the bandwidth of the meter, so quite attenuated.
If you are using a scope (I see you mention a 4ch 200MHz Keysight in another post) could you post screenshots of both input and output?
If something else, please describe your set up!
The following users thanked this post: raff5184
Offline IanB
« Reply #2 on: February 20, 2018, 12:24:47 am »
Does it make a difference if you put a small load on the output of the rectifier like a 1 k resistor? There are two reasons for this: firstly that diodes need to be conducting some current to switch properly; and secondly that you should measure the output voltage across a reasonably low impedance source to avoid phantom voltages upsetting the measurement.
« Reply #3 on: February 20, 2018, 12:37:25 am »
But:
AC voltages with a scope, DC voltages I tried both with a DSO and with a DMM, I get the same values, again across an open circuit
« Reply #4 on: February 20, 2018, 12:40:27 am »
I tried with a 10 ohm resistor load and indeed the DC voltage across it becomes smaller of a couple of orders of magnitude with respect to the o.c. voltage.
Offline IanB
« Reply #5 on: February 20, 2018, 01:01:23 am »
Lol. I said a small load, not a huge one  :o
« Reply #6 on: February 20, 2018, 01:17:30 am »
ah, you mean a large resistor that absorbs small current  :D
Offline IanB
« Reply #7 on: February 20, 2018, 01:27:15 am »
Yes, like the example I gave of about 1000 ohms. With a 5 V source voltage that should only draw a few milliamps.
Offline IanB
« Reply #8 on: February 20, 2018, 01:33:43 am »
You get peak voltage from a full bridge rectifier, not peak to peak. To get peak to peak, you need a Villard voltage doubler rectifier.
Well, quite. The OP is starting with a 10 V p/p AC signal and is expecting to get a rectified DC signal of a bit less than 5 V peak. The question is why might the rectified output be more than 5 V?
Offline danadak
« Reply #9 on: February 20, 2018, 02:50:42 am »
Begs the question, what V value are you measuring ? We are assuming
that you have a relatively large value cap on the output of the bridge,
so that AC is filtered out.
The 10V sinewave is +5V max to -5V min, so if there is no load on the
Cap/Bridge output then over a few sine cycles the cap charges to ~ 5V -
1 diode drop, or somewhere around 4.3 - 4.8 V. Thats if cap has low
leakage, and diode is nominally .7V when conducting. All this ignores
stray C coupling across diode, and other parasitics.
If using DVM, when you measure 10V sine, thats probably the average, or RMS,
unless it specifically has a peak reading capability. Compound this with the
frequency response of the meter probably only around 50 - 100 Khz, so good guess
you have >> 10V sine. Oscilloscope will give you better chance reading peak V.
Regards, Dana.
« Last Edit: February 20, 2018, 02:56:57 am by danadak »
« Reply #10 on: February 23, 2018, 03:54:27 am »
Hi again,
so I did some measurements using different load values. And I always measure rectified voltages higher than the AC RMS values so that the efficiency of the rectifier would always be  greater than 100%
I'm not sure what I am doing wrong, because I measured the voltages with different DSO scopes and multimeters and I have the same values
Offline IanB
« Reply #11 on: February 23, 2018, 04:00:29 am »
You may be doing nothing wrong. If you rectify a 10 V RMS sine wave and store the rectified output in a smoothing capacitor you are supposed to see a DC voltage of about 14 V.
Please give more information about exactly what your experiment looks like, what your parameters are, and what you are measuring. Unless you can give us that information we cannot help to explain what you are seeing.
« Reply #12 on: February 23, 2018, 02:29:00 pm »
Post a physical test setup photo please.
Sure, and thank you!
The wave on the scope is the AC input and the multimeter is the rectified DC
« Reply #13 on: February 23, 2018, 02:35:49 pm »
I only have a 0.01 uF smoothing capacitor, would it be enough to increase the voltage from 10 V RMS to 14 V DC?
Like I said the input is a 10 V peak-to-peak sine wave at 700kHz. I measure this wave (correctly measured with a digital oscilloscope).
Than I measure the output of the rectifier, that is the voltage drop across the smoothing capacitor (0.01uF) in parallel with a resistor. If I change the value of this resistor the input AC voltage drops as shown in the plots I attached a couple of posts above, however the DC voltage across the load still doesn't match the theory
Thank you for your help
« Last Edit: February 24, 2018, 05:40:23 am by raff5184 »
