Thank you kind sir, I didn't realise capacitors came in this package.
Is there any way of differentiating between capacitors and resistors from a visual point?
I am just generalizing here.
Generally resistors have a blue body for Metal Film variety.
Carbon film resistors are greyish and wirewound resistors are generally , but not limited to, red body. Actually wirewound resistors are dependant on the dye that the manufacturer wishes to use and/or has available.
Inductors have a sort of a lightish green body.
Capacitors, apparently, have a pink hue.
I knew about the resistors and inductors but the capacitors are as much a new bit information for me.
