I'm using the free version of ZenitPCB. I thought this was the forum for that program. If it isn't then nevermind. I previously had placed the mounting holes and all the LEDs I needed using this program. I thought I saved that file but I can't find it, so I don't think its a parts count limitation this time. I've got about 2/3's of the leds on the board that I had previously. I am able to add new parts, just not move them.
I'm not sure what you mean by cad program (mspaint or photoshop) or what I'd use them for.
I drew a quick schematic using FastCAD but that's just for reference. I'm not trying to import anything from it. I just want a simple manual place and route.
I'm not using an integrated cad program for a netlist as the job is so simple I'll route by hand - I've done it lots before. On jobs like this I commonly spend more time cleaning up after the autorouter than it takes to route by hand. (I have been designing boards for decades, the most complicated had two 325 pin ball grid array cpu's and 16 24 pin rams). I've used a few layout programs. I tried this software because my old software dongle died and I need a simple layout.
Eventually this board will have 2 mounting holes, 5 holes for wires, 2 diodes, 5 resistors, 2 transistors and 44 LEDs.
Here's the board file
