Hey guys
Have another coupe of situation,
I replaced the capacitors int he speakers as above, but the control pod for the Z-5450 system seems to power into Stand-by, but when trying to power on (power button), it lights blue (as it should) but for 1sec, then shuts-off for a few seconds, then powers back into stand-by. The capacitors in the control pod are all 'CapXon' brand, someone said they were crap, they were also the ones replaced from above post(s).
Unfortunately I don't have an ESR meter to properly test if these are bad, so I was planning on ordering a heap of replacement capacitors of equal value from farnell (element14) and just replacing them.. thoughts?
Problem #2 - Xbox 360 RROD
I had a xbox 360 with rrod, I opened it up to find some caps not looking so well. They also happen to be 'Rubycon' brand too. Not sure if they overheated on there own or from the other ship.. but they look a lil' burnt.
I was just gonna replace the 4x with
http://au.element14.com/rubycon/6-3zlj2700m10x20/cap-alu-elec-2700uf-6-3v-rad/dp/2346438 (add em' to my cart with the other stuff)
Not sure if they're totally stuffed.. but replacing them just in-case.
There's a couple of other caps starting (very little) swell.. but not sure if they too are like that from overheating or not.
I'd like to get an ESR meter, but they're a bit costly for me at the moment (no income). I was looking at the Bob Parker one, I hear it's good.
Thoughts?
Thanks guys, much appreciated
