I might be barking up the wrong tree, but I think there is a discrepancy here. What does Voltage mean? Charges are all around us, all the time. There is no way to do anything useful (in electrical terms) unless we can separate charges. Why? Stop reading right now and think about this. Why do you have to separate positive and negative charges to do anything?
Electrons just floating around are met with an equal amount of positive charge, and there will be no NET current flow. That is, if you consider all the charges floating around they balance one another. Now, assume we can separate those charges, that is, gather up a whole bunch of negative charge and dump them somewhere and do the same with the positive charges. Let's call it an electron cloud and a positive charge cloud. So, now I have potential to do something. If I connect a wire between these two clouds, a current will flow.
How do we define how much potential for current flow we have? Let's make up some term and quantify the potential here. This should start to sound familiar .... this made up term is called Voltage. That's right, voltage doesn't exist, we made it up to make our lives easier. Why we made it up and defined it the way we did gets complicated, but essentially we did it to make our lives easier.
