It is not polarized, so it is almost certainly a low esr ceramic 2.2 microfarad capacitor.
If you have any dead PC motherboards lying around, it will be full of 1uF surface mount caps and probably 10uF ceramic caps (the big ones), so you can pinch it them from there. Perhaps some 2.2uF as well, but there capacitors are not particularly accurate, you can replace a 2.2uf ceramic with two 1uF caps in parallel.
How can you tell the value? If you do not have a capacitance meter, get a 9V battery and a 1Meg resistor. Put a multimeter across the capacitor. Connect the capacitor and resistor together. The other end of the capacitor goes to the battery negative. The other end of the resistor goes to battery positive.
If the voltage across the capacitor rises from 0V to 6V in just over 1 second, it is 1uF. A bit over 2 seconds it is 2uF. A bit over 10 seconds it is 10uF. These capacitors can easily be out by over 20% - it doesn't matter when used for decoupling or filtering DC.
Edit: I am assuming this is a low voltage capacitor. I do not know what the "french inverter circuit" is. If it has mains across it, DONT use a ceramic capacitor.
