Forgive terminology and even conceptual errors. After all this is the beginner section!
I am wondering about polarized caps in reverse.
One way you normally use a decoupling cap is to block DC bias voltage, in the direction of your AC signal output. eg, to remove the DC offset from the output of a single ended (virtual ground) op amp.
But also it's not uncommon to block a DC bias voltage in the "forward" direction of the cap, while generating an AC signal in the "reverse" direction of the cap. For example,
http://www.epanorama.net/circuits/dynamic_to_electretinput.html . The output direction of the mic is in the reverse direction of the cap.
As best I can understand, this works fine as long as the AC signal peak voltage is not higher than the DC bias voltage. If that were to happen, the more positive node would be on the negative side of the cap and this would (could) fry the cap. Is that a correct understanding?
Considering the forward-only case again, I also understand that an AC decoupling cap has another effect in that it creates an RC circuit with your load. So the value of the cap has to be selected properly depending on your frequency requirements and the load resistance. eg 10uF cap with 22k resistor as a low pass filter for audio frequencies.
Does the cap work the same way in reverse? I mean in my example where you have an AC signal that is going in the reverse polarity direction of the cap (yet still under DC bias voltage present in the forward direction), will the cap in the reverse direction still form an RC low pass filter?
