Yeah a deep cycle battery, probably a car battery really with a label saying leisure. I have my
doubts as to whether the internals are any different.
Actually, they
are quite different.
The car battery, designated SLI for Starting, Lighting and Ignition, is a relatively light construction in which the electrodes are thin and with a large surface area.
This large area facilitates the high current that cranking a cold engine needs. According to
this tutorial they are designed to be drained as little as 5% before needing recharging to keep the internals in good condition. Deep cycling will destroy them quickly. Deep cycle/leisure batteries are of heavier construction and can take discharging down to 20% capacity repeatedly.
I think the problem is im pulling approx the same amperage as the charger can put out and its fighting to keep
it fully charged. I wonder is a smaller fixed amperage charger would work better?
Need something to just put out a steady charge and stay cool.
By the looks of things, your CTEK charger seems to be one of the
more popular and proven chargers for use in caravans. I can't help but think that it's quite up to the job, despite my former doubts. As I wrote before, if you're running anything off the battery+charger, the charger will supply everything up to 3.6 A. Anything over will come from the battery.
This means that at more than 3.6 A, you will not be charging but draining the battery, albeit at a lower rate than without charger. As soon as the load drops below 3.6 A will some of the output charge the battery. If the load is disconnected completely, the battery has the full 3.6 A charge available, which it will only take when its charge level is low enough.
IMHO, you can get away with using the CTEK as is. Even if its lifespan is limited by the heat a little, that may still mean you can expect many years of service from it in camping type of use (i.e. a couple of weeks a year).
