The battery should never be discharged though. Its always kept at home and topped up monthly,
occasionally i use it to power something to drop the voltage a little bit and then leave it on
charge a small CTEK charger 3.6amp max? Thats designed to be left on 24/7.
In the caravan the battery is only there to stabilise the voltage and a backup if the main
power fails. Previously the battery was used to power the electric motors to move the
caravan, so a small discharge before actually using it.
But we swapped storage yards and can now reverse upto the caravan.
It starts with a fully charged battery and during the day we are mostly out so no 12v draw at all
and just the lights and waterpump later on and in the morning. Nowhere near enough power
to drain the battery. It does take a day or so for the voltage to drop.
I had the same battery attached to an inverter and running a 100w bulb for over 4 hours and
the voltage was still at 12.2v. So the battery is good and we do not draw that amount
of power in a 24hr period.
I think the charger maybe actually draining the battery also.
I have several chargers that can be used in its place, either wired in 24/7 or used on a plug as
and when needed.
Going to wire it upto a battery now and see if it draws power.
Thanks.
PS.. even if i dont re-use it i would like to know what to look for and have a play with it. Eager to learn
