Author Topic: CCFL Lamps  (Read 1051 times)
Offline anker_byTopic starter
  • Country: pt
CCFL Lamps
« on: October 01, 2017, 12:13:47 pm »
hello everyone, I need to buy some CCFL for a laptop and the screen, but the problem is where i can find some supplier/store where i can buy in european union, if anyone give me feedback, thanks
Best Regards,
- Anker_by
Offline Quarlo Klobrigney
  • Country: pt
  • This Space For Rent
Re: CCFL Lamps
« Reply #1 on: November 21, 2017, 10:04:51 am »
I do a retrofit to LED strips and the proper driver. They are more available than CCFL's. Do a Google search and you will find many sources.
Voltage does not flow, nor does voltage go.
Online Zero999
  • 0999
Re: CCFL Lamps
« Reply #2 on: November 21, 2017, 12:01:30 pm »
That will work but it's likely the colour rendering will be poorer with LEDs, than a CCFL, especially if the display was designed for CCFLs.
  • Country: pt
Re: CCFL Lamps
« Reply #3 on: November 21, 2017, 01:11:24 pm »
Or just get the right color temp LEDs or adjust the colour temp in the settings. Certainly better than a black screen..
Online Zero999
  • 0999
Re: CCFL Lamps
« Reply #4 on: November 21, 2017, 01:35:52 pm »
That still won't give as good colour rendering as the original CCFL.
The screen's filters will be designed to match the spectral output of a CCFL and if it's changed to LEDs, the colour rendering will suffer. LEDs is they have a different spectrum than CCFLs, even if the colour is exactly the same. One of the common problems is they lack the red end of the spectrum. Decent LED backlit screens have LEDs with special phosphors or a combination of blue/violet dies with a phosphor and red dies to produce the missing red end of the spectrum.
The bottom line is, replacing the CCFL with an LED will work, but don't be surprised if it gives disappointing colour performance.
