Good questions!
1 - No, the signal can come at any rate. This is normally how digital gates and flip flops work. It can be high for a month, low for a microsecond and it'll count it.
1a - yes, you can just attach a switch. However, the 4040 can count very quickly, and will count the various momentary contacts that occur when the switch contacts close. Google "switch debounce"
1b - Same deal with the reset, but perhaps you don't care about debouncing there since it'll just reset a bunch.
1c - NXP's datasheet (
http://www.nxp.com/documents/data_sheet/HEF4040B.pdf) has a nice timing diagram that shows you it counts when RESET is low. By low I mean ground or near to it, and the same voltage as on pin 8 (Vss)
1d - Depends on your debouncing circuit a bit. But as a maxim, a digital input shall never be left floating. For example, you can pull it up with a resistor, then pull it down with your switch to ground. If you just connected it to a switch, the other side of which was connected to ground, then when the switch was open the input would be left floating. The only time you can make an exception to the floating input rule is that you know for a fact it's fine and why.
2 - Q outputs you mean? No pulling up or down is for inputs only.
3 - + to 16 and - (ground) to pin 8. Vcc/Vee and Vss/Vdd are fairly opaque as they assume you know how things are connected up inside the chip. Vcc = something to do with collectors in bipolar (eg, TTL) chips, Vee emitter. Vss source in (C)MOS chips and Vdd refers to the drain. All I ever needed to know was Vcc and Vdd were the positive terminals while Vee and Vss get connected to negative or ground.
Getting a little beyond your questions: 1a - there are some digital components that can only work so slowly. For example DRAM will "forget" what you put in it's memory after a few milliseconds unless you constantly refresh it. Many early microprocessors also worked this way, and it was a big deal for battery operated applications when processors that you could clock down to zero came out. To know check the datasheet and look for a minimum clock speed.
1c - for common chips like the 4040 counter, check a few datasheets out from various manufacturers. Some are more clear than others. Some leave important information off them, which is I think because "everyone knows these parts."
1d - eg, some parts have internal pullups.
