I know it's an old chip - but I am struggling with how to set R1, R2 and C to get a needed frequency. I understand I can use a crystal, but for now I'm trying to understand the values. From my own experimentation there are some limits that aren't clear to me - so I wondered if there isn't better (for dummies kind) materials explaining the relationship between the R and C values. I don't get a traditional RC formulator to work, mostly because there are two resistors and well, I find lots of different setups out there that aren't matching the datasheets including pulling the C to ground through a diode ... anyway ..
Question: What formular should I use to calculate R/C for a given frequency? Let's say I want the pulse on pin 11 to be 1Mhz - how do I determine the C and R values? Reading the very old fax/photo copy TI uses, I see the following (which is hard for me to grasp):
Rs is 2Rx to 10Rx
T = 2.2 RxCx
Which R is this talking about? Rs barely seem to have an effect on the frequency - Rx seems to cut out the frequency when I get close to 200Khz on Q4. I'm using a 10pF cap and using less than 2.2kOhm as Rx just makes the oscillation stop. I've tried 5v and 10v input - this is definitely a circuit that gets more stable at higher voltages, but 5v is what I'm trying to make it work at.
The datasheet also have two different max values for frequency on the input (one says max 3.5 Mhz, the other says "3.5Mhz->7Mhz). Since this is ancient documentation/chipset I'm obviously not reading it right, so I'm hoping for some guidance on how to read this so I can set things to the proper values.
Thanks.
