As I understand, when you charge a capacitor, the initial voltage you see across it is due to its internal resistance.
So if you charge a capacitor with 1A, and it has 1Ohm internal resistance, the instantaneous voltage you see across it will be 1 Volt.
What I dont understand is if we made the internal resistance 10Ohms, then the voltage will be 10Volts. So we have charged the capacitor faster by somehow increasing the resistance? This doesnt make sense.
So my real question is to do with transistors. If above what I said was true, why not make MOSFETS with internal gate resistances of 80Ohms which would then begin to turn on instantly even if we only had 200mA into the gate - there would be absolutely no delay for the gate voltage to reach the threshold voltage. But surely, this cannot be the case.
