Don't try to electroplate gold at home. It requires noxious chemicals like boric acid and aqua regia. The only metals I'd recommend for home electroplating are copper and tin since these can be done with acetic acid and low-strength muriatic acid respectively.
You can probably find a company nearby who will do electroplating, but pricing is a bit of a crapshoot.
not sure what you mean "noxius": dangerous, forbidden, toxic?
well, was thinking in doing it in the celler. Though there is not so good ventilation, but could put a ventilator. Do you think that would work? I will start anyway to "burn" pcb's etc. there.
Dangerous, toxic, fuming, corrosive, potentially explosive.
Correction, you don't need boric acid for the nickel plating, you need sulfuric acid. You also need aqua regia (mixture of hydrochloric and nitric acids) to electroplate gold.
Not saying that you can't do it at home; but it will shorten your life expectancy and probably give your life/medical insurance agent an aneurysm. There is both short term danger (acid spill, poisoning, fume inhalation, explosion, electric shock) and long term (lung damage, cancer).
Find someone to do the plating for you. If it's not too expensive, plating could be a good solution. Stainless steel is ok, but keep in mind it's not really stainless; given enough moisture and the presence of mild corrosives (such as those found in soil) stainless steel will still rust. Just, more slowly than carbon steel or copper.
